I have a liberty Pro 2. Do i need to link to both the Liberty Pro 2 bluetooth and the Liberty Pro 2 - L bluetooth connection? or just one? what is the difference?
Do i need to link to both bluetooth signals?
Yes both, it helps with Bluetooth 5 and allows you to use just one bud. You normally in sequence pair first with the right bud then it asks you to pair with the left bud.
I like that you can also pair the right with your phone and pair the left independently to a second device like a laptop… granted it’s a bit tricky…
Not quite multipoint, but I’ll take it.
TS1
