Does anyone know how to disable the alerts in the app that you get from opening and closing doors? I have disabled the push notifications for door sensors, but I have to manually delete the alerts that are generated whether or not the alarm is enabled.
Disabling Entry Sensor Alerts
thanks, I thought I was in the correct forum.
Yes or no!
But there are more EUFY-users at the other one.
So better is to do an inquiry twice.
