Difference between powercore, powercore II and powercore+?
Which one is the latest model?
@Insider can probably help you out!
Hi @N114,
Anker is still releasing PowerCore, PowerCore+, PowerCore II models. No one series is newer than another. If you provide specific models, I can try to tell you which one is newer.
What device(s) would you like to charge? I can help you pick the best portable charger for you!
