Developer settings
nebula capsule developer settings
I taped Android version 5 to 7 times and it
Is asking for password?
I would contact nebula directly for the password at
Support@seenebula.com
Or maybe @AnkerOfficial or @AnkerTechnical can provide the password.
What are you trying to do in the developer settings?
I download the spectrum TV. It opeanes ok and when I go to live TV it say developer options enable desable to continue to live tv
Almost forgot
A pop-up with link to developers option opens the fist time. I was not sure what to do but it closed itself.
I tried locking for it but could not find it and opening the TV app and clicking developer option did nothin
Sounds like a cool feature to have. As I have already said you best bet is to connect nebula directly or wait for a response from @AnkerOfficial @AnkerTechnical
Try reinstalling the app to get the pop up back
Best of luck
@dinny43 please send email to us (support@seenebula.com ) We will help you to fix this issue. Thank you!
