DEAL -- Soundcore Infini for $59.99 (save $20) & Infini Pro for $199.99 (save $50)
# Soundcore Infini Integrated 2.1 Channel Soundbar by Anker, 35-Inch Soundbar for TV with Bluetooth and Wired Connections, Speaker with Built-In Subwoofers, Deep Bass, for Home Theater Audio
Deal for $59.99 - Save an extra $20.00 when you apply coupon
About this item
Product description
2
Deeper and Deeper:
Infini’s built-in dual subwoofers and bass ports deliver deep bass, intensified by exclusive BassUp technology.
1
Movie Mode:
Intensified bass and surround sound fill your room to immerse you in the movie experience.
4
Music Mode:
Your songs are boosted by well-balanced highs and mids, and a huge hit of bass.
3
Dialogue Mode:
The mid-range is enhanced to ensure you hear speech and vocals with incredible accuracy.
5
Slim Design:
The 2.2 inch design fits comfortably under your TV or can be discreetly mounted on the wall.
6
What You Get:
Soundcore Infini, power cord (4.9 ft), remote control, 2 AAA batteries, 3.5 mm to RCA audio cable (4.9 ft), digital optical cord, 2 wall mounting bolts, 2 wall mount brackets, wall mounting template, user manual.
Soundcore Infini
Movie Mode
Captivating cinematic moments are brought right into the heart of your home via 103 dB of breathtaking virtual surround sound.
Music Mode
Exclusive BassUp technology intensifies and drops the bass produced by the dual built-in subwoofers and bass ports to new depths.
Dialogue Mode
Infini’s dual tweeters and advanced DSP technology enhance the mid-range to ensure voices are crystal-clear and easy to understand.
Flexible Placement
The dual-orientation design delivers the same cinema sound experience whether the soundbar is placed in front of the TV or mounted onto the wall. Infini’s 2.2 inch height is barely noticeable and won’t block your view of the screen.
Multiple Input Options
Connect to your TV or other devices using an optical, digital coaxial, or AUX connection. For convenient streaming, use Bluetooth to link to your mobile device wirelessly.
Dual Control
Infini has both a remote and built-in buttons for convenient control of the volume, sound modes, and switching between wired and wireless connections.
What You Get: Soundcore Infini, power cord (4.9 ft), remote control, 2 AAA batteries, 3.5 mm to RCA audio cable (4.9 ft), digital optical cord, 2 wall mounting bolts, 2 wall mount brackets, wall mounting template, and user manual.
Features & details
  • Immersive sound: The integrated 2.1 Channel build is optimized to fill your home with 103 dB of rich Surround sound.
  • Huge hit of bass: two built-in subwoofers and bass ports produce low frequencies that are further intensified by our exclusive bassup technology in music mode.
  • Stunning clarity: dialogue mode utilizes infini’s Dual tweeters and our advanced DSP technology to put crystal-clear voices center stage.
  • Flexible placement: extended 35" Design is optimized to deliver the same stunning sound whether wall-mounted or placed in flat under your TV.
  • Convenient input options: connect via optical, digital, or coaxial inputs. Alternatively, use AUX cable or Bluetooth streaming to Link to more devices. Use the remote control to easily control the soundbar.
Link to purchase Soundcore Infini
Soundcore Infini Pro Integrated 2.1 Channel Soundbar with Dolby Atmos and Built-in Subwoofers, TV Surround Sound System with 4K HDR Pass-Through, HDMI Arc, Bluetooth 5 Wireless Music Streaming
Deal for $199.99 - Save an extra $50.00 when you apply coupon
About this item
Product description
Dolby Atmos
The world’s leading surround sound technology transports you into the action with breathtaking, cinema-like audio that appears to be coming from all around you, including from overhead.
Cinematic Sound
Two built-in subwoofers, mid-range drivers, and tweeters are paired with dual bass reflex ports to work in tandem with Dolby Atmos. This exceptional combination fuels sound with astonishing clarity, richness, details, and depth.
3
HDMI ARC
Two-way audio is delivered via a single cable and lets you adjust the soundbar’s volume via your TV’s remote control.
Bluetooth 5
Conveniently connect your phone or other mobile device to Infini Pro to stream music, podcasts, and more.
Soundcore App
Use the Soundcore App to switch between sound modes, choose an input source, and adjust the volume.
7
What’s In The Box
Infini Pro, 1.5 m power cable, remote control, 2 × AAA batteries, 1.5 m HDMI 2.0 cable, 4 × screws, 2 × wall mount bracket, wall mounted bracket locator card, user manual.
Soundcore | Hear It. Feel It.
A Brand Under Anker Innovations
Dolby AtmosⓇ Technology*
Dolby Atmos transports you from the ordinary into the extraordinary with breathtaking, moving audio that fills your room and flows above and around you. Using this cutting-edge technology, Infini Pro can reproduce cinema-like sound from a single soundbar.
Cinematic Atmosphere
Two built-in 3-inch woofers, 2.5-inch mid-range drivers, and 1-inch tweeters are paired with two bass reflex ports and our exclusive BassUP technology to deliver 105dB of audio power with intense low frequencies.
Enhanced Entertainment Experience
Movie Mode: Feel the bass as it reaches new depths, bringing heart-stopping movie moments right into the heart of your home. Dialogue is brought to you with enhanced clarity to ensure you hear every single word.
Music Mode: Treble is enhanced, giving the music a greater sense of depth and three-dimensionality.
Voice Mode: Makes voices clearer and increases the volume level. Designed for enjoying TV shows, news, and more.
4K Pass-Through
Compatible with 4K HDR and Dolby Vision to allow you to enjoy the latest movie formats in stunning quality.
HDMI ARC
Simplify your setup by using a single HDMI cable to connect Infini Pro to your TV’s ARC port and control volume using your TV’s remote.
  • Dolby Atmos requires HDMI passthrough from a Dolby Atmos-Compatible source device.
Features & details
  • Dolby AtmosⓇ: The world’s leading surround sound technology reproduces breathtaking, moving audio from all around you—even overhead.
  • Built-In Subwoofers: Infini Pro’s integrated 2.1 channel design pairs two front-facing 2.5-inch mid-range drivers and 1-inch tweeters with dual, up-facing 3-inch built-in subwoofers, symmetrical bass reflex ports, and exclusive BassUp technology for intense low frequencies and 105dB of room-filling sound.
  • Customized Sound Modes: Choose from Movie, Music, or Voice mode to enhance Infini Pro’s sound for the media you’re watching or listening to.
  • Versatile Input Options: Choose from HDMI, HDMI ARC, optical, or Bluetooth 5.0 connections. Also supports 4K HDR and Dolby Vision pass-through to 4K TVs.
  • Slim Design: Infini Pro’s low profile, streamlined body is 36 inches in length, and is wrapped in a discreet black fabric to allow it to blend in effortlessly with your interior.
Link to purchase Infini Pro
Good deal, thanks for sharing.
Great deals @Shenoy! Thanks for sharing!
Just a tip. In the title, you included the sale into the regular price for the infini, but didn’t do so for the infini pro. It’s usually best to stay consistent :wink:
Dam worth it just for Dolby Atmos :sunglasses::open_mouth:
Sweet deals, have the Infini myself and think its excellent :slightly_smiling_face: Thanks for sharing @Shenoy !
I totally agree.
Huge price difference between the two. Is the Infini Pro worth the extra 140?
Thinking of pulling the trigger, but need some persuasion!!
Good catch @TechMan had first included only Infini Pro later after adding Infini, missed to change the deal price, changed it now
There are some great Reviews for Infini Pro, Does have great audio output with Dolby Atmos
https://community.anker.com/t/my-soundcore-infini-pro-review/
https://community.anker.com/t/it-is-finally-here-my-review-for-the-infini-pro/
@ndalby these are some great deals I was waiting myself for very long but didn’t see them till late. Hope Members can make use of these…
Not sure if we may see better deals on 15th/16th
Great deal!! :ok_hand:t3:
