[DEAL EXPIRED] Anker Powerhouse 200 Deal for $199.99!
with discount code ANKERWFH3
Buy here
Anker PowerHouse 200
2
3
Leading Charging Technology
  • Thanks to pioneering innovation and an insistence on using only the highest-quality materials, Anker sets the market benchmark for USB charging and connectivity.
PowerHouse 200
The successor to the original clean and silent portable generator.
Ideal for outdoor adventures, emergencies, or as supplementary mobile power for home medical equipment, PowerHouse 200 has the power, versatility, and portability to handle any challenge.
  • Enormous Capacity
  • 1 DC Outlet (12V), 1 AC Outlet, 1 USB Power Delivery Port, and 2 High-Speed USB-A Charging Ports
  • Recharges via USB-C, AC, or Solar
  • Superior Safety with MultiProtect
4 4 5
Power for All
Charge or power multiple devices at the same time; without sacrificing power or speed.|#### Power Delivery In and Out
Recharge PowerHouse itself, or give a full-speed charge to a wide range of USB-C devices via the dedicated Power Delivery port.
Charge Anywhere
The ultra-compact design lets you charge anywhere you need to, be it inside your house, your yard, or in your garage.|
6 5 8
Award-Winning Design
PowerHouse has been recognized by iF and Red Dot for its innovative and portable design.
Superior Safety
Anker’s world-renowned safety systems keep you and your devices protected.
Suitable for Small-to-Medium Devices
Please note that PowerHouse 200 only supports devices with a rating less than 100W.|
PowerHouse 200
  • The More Portable Clean & Silent Generator
From Anker, America’s Leading Charging Brand
  • Faster and safer charging with our advanced technology. 50 million+ happy users and counting
USB-C Port Information
  • To charge a USB-C device with the PD port, press the PD button before connecting your device. If the device is connected before the button is pressed, the device will use its battery power to charge PowerHouse, which may damage the connected device.
  • Compatible with USB-C MacBooks / iPad, iPhone 8 / X / XS / XS Max / XR (Lightning cable required), Android smartphones and tablets (including the Nexus 7), and other USB-charged devices.
  • Incompatible with HTC 10, HP Spectre, Dell XPS series laptops, Dell Venue series laptops, Asus series laptops/tablets, as well as Lenovo ThinkPad 470s and ThinkPad X1 tablets. Some USB-C laptops which require an input over 30W may not be compatible.
  • Does not support high-speed charging for MacBook Pro, Samsung W700, Lumia 950, or Motorola Z Force Droid Edition. Nintendo Switch will not charge when connected via HDMI.
  • Not compatible with devices with an input below 50mA (e.g. some Bluetooth headsets and GPS devices).
Pass-Through Charging
  • PowerHouse is capable of pass-through charging while connected via a vehicle output or AC outlet. It will not replenish its own battery if the power requirements of connected devices exceed that of input.
Notes
  • Solar charging requires a 5-22V solar charger with 5.5*2.1 mm DC output. Recharging will be faster at higher voltages.
  • AC Port Frequency Setting: Press the PD and AC buttons at the same time to change the frequency. After entering option mode, press the PD button to switch between 50% (50Hz) and 60% (60Hz).
PowerHouse 100 must be coming soon…
If i get a good deal on it, I will definitely go for PowerHouse 100!
This cam sure help you in an emergency
Announced last October, it was originally supposed to be released last December, then in April, and now maybe not until June due to COVID–19?
I would love to have one of these for a corded drill, regardless of what I do I seem to always be about a foot short of reaching an outlet. I think this would be great for closing the gap. Great deal, thanks for sharing!
note the 100W AC limit, compare with your drill’s power input.
It’s a small drywall drill, the powerhouse could definitely handle it.
Nice deal on a power house!
great deal, however it has now expired!
