Cosmos Max Bluetooth Connectivity
I recently received my Cosmos Max, and want to connect to my Bluetooth receiver for the audio. However, I cannot find any Bluetooth settings to be able to connect wirelessly to my audio system. Is there a setting or someway to access the Bluetooth settings being advertised?
I owned it for a few hours, it was in an easy obvious spot, settings, bluetooth?
Nose around, it’s not hard to find.
The one you had is different, you had a capsule Max. This is the Cosmos Max which is the round 4k projector.
@jacky.2herman follow these instructions to connect Bluetooth device
I just received my nebula cosmos max 4k yesterday, but is not recognizing my bluetooth speakers system Rockville TM80B, other android devices can see the speakers, I unpaired the speakers with any other device, restart speakers and nebula device, but nothing happen, my Nvidia shield ( android tv too ) and my xiaomi android box also can see the Rockville TM80B, Any help will be appreciate, everything else in the nebula cosmos max 4k so far is fine
You’ve tried nearly all the advice already apart from you’ve not reset the speaker.
So delete all pairings, turn off all Bluetooth of all previously paired devices, reset the speaker, then attempt to pair the projector with the speaker.
I called Rockville, spend time with the tech support on the phone, regarding how to reset the Bluetooth Rockville speakers, but there’s no combination of buttons for reset the speakers, I will try your advice this weekend to turn off all the bluetooth devices previously paired with the Rockville and try again, I will let you know, but is strange, every other device is working with no issues , thanks
