Hi, Just got my Nebula Cosmos 1080P after a long wait but while I was able to install and make the Amazon prime & Hulu app’s to work ; I am unable to download Netflix or Disney + app’s ( 2 streaming services my family uses most !) - I get a message that these app’s are not supported on this device ?
Not sure what the issue is?
Would appreciate of anyone else has faced same issue and been able to resolve ?
Cosmos 1080P
Hi @Amol_B as this is a new release I would suggest you reach out direct to support@seenebula.com who should be able to help you with your issue.
you need to download the nebula manager app from google store on the projector
