Hello all.
I’ve a wireless charger that’s plugged in all the time. Do you think this will be ok?
I’ve also added a 6 port charger that I’ll do the same with to my xmas list and don’t want to do them both damage!
Hello all.
I keep an Anker 5 port charger plugged in 24/7 and haven’t had any issues. I did measure it with a Kill-A-Watt meter and found the power draw (when not in use) costs less than $0.50 a year.
Thank you for letting us know your concern.
Please be assured that it will be fine.
Hope that helps and do not hesitate to contact us if you have any other inquiry.
I have a 6 usb port 60W thing and I keep that plugged in 24/7 and have had no issues. I’ve had the older 5 port one plugged in for about a year without issue
