Connection from ROAV - iPhone ... password :goroavcam is rejected
Roav
#1
Trying to connect my new ROAV S1 to my iPhone via the WiFi but the password ‘goroavcam’ is rejected as invalid by my IPhone.
This password is from the owners manual that came in the box.
What else can I do to connect the phone.
#2
Hi @edwards.paulmichael,
There is a reset button located near the power input (the reset button is located at number 10 on the diagram below). Try resetting the unit, which should restore the goroavcam password if it was somehow changed. If it still gives you trouble, please reach out to support@goroav.com and they’ll be happy to help!
#3
I have the A1 and this has never happened
