How do I connect my soundcore mini to Alexa!!? Alexa says cannot find it!!! Any help much appreciated
Cheers Simon
Connecting to Alexa
I don’t think Soundcore Mini supports Alexa. As far as I can see, you can use the speaker through Bluetooth, AUX, Micro SD, and FM (if I’m not wrong)
Here’s the link from Amazon on how to setup a bluetooth device: https://www.amazon.com/gp/help/customer/display.html?nodeId=202011820
Make sure they are close enough for pairing.
Are you wanting to connect to it through Bluetooth as the other user suggested, or other means?
