Confused about the difference between Anker wireless chargers
I’m looking for the best wireless charging stand to use with recent phones like a Samsung Galaxy 7/8/9 or recent iPhone, what’s the best/newest charger from Anker? I’d prefer to buy from amazon.ca and these are the options:
  1. https://www.amazon.ca/Wireless-Anker-Qi-Certified-PowerPort-Included/dp/B0753Z4PGC
  2. https://www.amazon.ca/Anker-PowerWave-Wireless-Qi-Certified-Compatible/dp/B078TDLHY9
  3. https://www.amazon.ca/Anker-Qi-Certified-Compatible-Fast-Charging-PowerWave/dp/B07DBXZZN3
  4. https://www.amazon.ca/Anker-PowerWave-Qi-Certified-Compatible-Qi-Enabled/dp/B07DBXNV58
Also would this be the proper/best AC adapter to use?
https://www.amazon.ca/Anker-PowerPort-Compatible-Qualcomm-Certified/dp/B077HFFLMS
Thank you!
You’ve got the right wall charger. My recommendation out of those would be #4. However, #2 is just as powerful.
As long as it says fast wireless charging, differences in charging speeds will be unnoticeable…
