Compatible USB-C extender cable for 364 10-in-1 USB Hub
I asked this a couple of months ago but didn’t get an answer so I am reposting:
Is there USB-C extender/cable (Anker or otherwise) that I can use to extend or replace the 364 10-in-1 hub’s hub to laptop connection?
Will it be a Thunderbolt or USB-C 3.1+ cable/extender?
Thanks!
You might want to reach out to Anker Support to see if they have any recommendations. I would personally try a thunderbolt cable.
Thanks for the advice. I did contact support and this was their reply:
We appreciate your support and interest in our products and are sorry for replying late due to the labor holiday. Sorry that we would not recommend using any cable extender, but if you’d like to get one longer cable that could work with Anker 364 USB C Hub (10-in-1, Dual 4K HDMI) , you may consider Anker Powerline II USB-C to USB-C 3.1 Gen 2 Cable (3ft)
https://www.amazon.com/dp/B072JYDQ7N (If you’re not from US please let us know, we’ll provide the link in your country)
I actually bought another 3ft USB-C 3.1 Gen 2 cable from a 3rd party. It worked like a charm.
The extra 1.5 feet of laptop to hub length gives me a lot more flexibility on my limited desktop space!
Thanks again!
