Cheapest Power Draw prizes?
Bolder LC90 Flashlight
PowerCore Speed 10000
Anker SoundBuds NB10 Bluetooth Earbuds
Cost of 1 Entry: 1 PowerBucks
Naturally, I submitted the maximum :smiley:
It was stated due to the 2 year anniversary of the forum all prizes would cost 1 buck.
This if I’m not mistaken is the second or third time they did this
Yep as @elmo41683 has mentioned, not the first time (3rd I think) and no doubt won’t be the last :slight_smile: Would be rude not to have flutter…all in on the torch :grin:
As I won the LUMI, a torch would not be bad too.
But this time the winners should be others,
.:grin:
Random is random, I hope. If it lands on you, then it’s all good :slight_smile:
Nice! Do they allow the same user to win multiple times in the same week/month?
That’s a question for @AnkerOfficial :slight_smile:
If I recall correctly, the answer to this question is:
  • A user can only only win 1 prize per week
  • Winning does not hurt your odds to win the following week (i.e. a user can win two weeks in a row)
I do not care much about it.
If there is any ā€œneedā€ of an item ( kids or friends)
I take part,
otherwise I hope there is a winner who needs it.
I was planning to put my bucks to use but there are somewhere around 600+ entries. The odds of winning are low.
Its only 30 bucks total, you surely can make that back in a day
I can and I will. I’m thinking posting to all 3. :grin:
