Charger Question
I have the Soundcore Liberty Pro 2 product. Works great but I find shortcomings in the product manual both online and as included with the product.
My question is simple. I understand to charge the case to use the provided USB cable (or optional wireless charger). What is less than clear is how to activate a charge from the case to buds as the charge in the buds decreases.
Does this happen automatically when the earbuds reaches a charge condition below 75%? 50%? 25%? - some other value?
Will the case automatically charge the earbuds and at about what level of battery depletion of the earbuds?
Is there some indication of when the case needs a charge? Any series of alerts or lights other than an earbud audio alert that may only leave a few minutes of use on the product?
When you open the case you will see 3 lights when the case is at full charge. So when it gets to 1 light, the case is getting low. I believe if the earbuds are not at a full charge is when the earbuds would activate a need to charge. For the case, I was thinking when you have one light left and it is blinking is when the case is in a need to charge. My documents are in my bedroom n wife is asleep. Will try to remember when I get a chance to gra it.
The earbuds will charge everytime they are placed inside the case regardless of their state of charge. But the will stop charging once at 100% charge. And the case has 3 LED on it that lets you know its state of charge. But if you are worried about running out of juice, you can put the earbuds into the case for 5 minutes and get an additional 2 hours of playtime
