Is it possible to charge Eufy Can with a Ipad charger. Is it a good idea to charge them continually. I do not want to harm the batteries.
Charge Eufy Cam
Its fine to charge continuously, and no, no iPad charger can charge it. You need mini USB. Message me if you need any more help!
Thanks’ for your answer. I did not express myself clear enough. I’m aware Apple use their own standard for the plug connected to the device. But the cable can be changed to a USB to a mini USB. I’m more concerned about the transformer. Will the electric output fit for Eufy Camera – volt and milliampere (mA). I’m looking forward to an answer – thanks.
Oh yeah, the power brick from the iPad will be fine.
