Ceiling Mount
I need to mount the EufyCam e on a flat ceiling. The recessed screw hole doesn’t work with generic mounts that expect a flush screw hole.
Has anyone come up with a good ceiling mount solution that can be bought off the shelf.
I think the screw is too short on something like this due to the recessed screw hole on the eufy.
Could you not buy a different screw from your local hardware store?
