Case for Soundcore Motion+?
Hi there,
Just received my Motion+ - haven’t even heard it yet, as I’m waiting for it to charge!
I have a great case for the A3143, but this speaker is larger.
Has anyone found a protective case that suits the Motion+ ?
This case is a bit oversized but you could fit two Motion+ or one and a powerbank/charger.
Motion+ dimensions
Thanks El Duderino - looking for something fairly compact I can throw in a backpack - I’ll do a bit of searching and will update the thread if I find something.
No problemo had a feeling you were looking for something smaller. Let us know what you find.
I am sure you find such a box and with some skills you may attach foam to make it fit for that speaker.
aliexpress has some portable cases for the motion+.
