Hello!
I just acquired the Capsule max.
Has anyone ever tested the USB 5V step-up cable to load the device from a USB charger?
Would loading it that way damage it or would loading just be slower?
Thank you
Regards
Hello!
Thank you
Regards
Thanks for your inquiry.
The USB-A port on Capsule Max outputs at 5V/1A. If you’d like to use that port, we do not recommend charging devices with higher input requirement than 5V/1A.
Thank you!
Anker Support Team
Hello,
Actually, i was thinking about charging the Capsule Max from a USB port (like one from a computer) using that kind of cable :
(Not using the Capsule Max as a powerbank)
They are asking about step-up input.
If you did want to then:
So if 15V 3A then that is 5V 9A which exceeds USB, so you’d get slower Max recharging, seek one of the 5V 3A options.
Great, i’ll give it a try then
thank you
