Hey there,
My eufybase and cameras eufy C and door sensors are useless since today. For some reason, the app is not working anymore, giving me a message like shown on pic.
I did remove and add back everything (a real assle to reach the outdoor cameras to synch). But didn’t change anything, can’t connect to it.
Any clues?
Can't connect to my system anymore
Mine works fine. I am running the app on iOS with the latest firmware, don’t know if that makes a difference.
I’m on Android, firmware and app up to date.
Seems to work when I’m home. Had the system for 7-8 months, never had an issue like that.
Is your app up to date? Try setting everything up again
Yes app is up to date. I noticed yesterday that if I force close the app, it seems to work when I reopen it. I may have to uninstall and reinstall the app to see if it helps.
This is what I would recommend.
Good luck, hope that helps.
