I have just purchased the Liberty 2 Pro earbugs from yourself.
I have installed the software on my Windows10 desktop…
After connecting to the bluetooth, I can only get sound to arrive in the left earbud. The right earbud eppears dead.
We are sorry to hear there is no sound output in the right earbud. According to the information you described, the issue you are experiencing is very unusual. Please try the following steps to see if it helps at all.
When there is a pop-up window for you to confirm pairing. Select “pair”. If you select “cancel” accidentally, you need to delete the earbuds from the device’s Bluetooth history and re-pair the earbuds.
