I’m eyeing the powercore+ 26800 PD but noticed that other Anker devices with PD support trickle charging for Low power devices.
Can the powercore+ 26800 PD do that too?
Unfortunately, no. Currently, the largest portable charger with Power Delivery and Trickle Charge is 10000 mAh.
Ah I see. That’s the Normal 10k PD, Redux and Slim yeah? The normal 10K PD has it too?
That’s correct.
Well, looks like the Powercore+ 26800 45W does support trickle charging
Not entirely clear, though – the Canadian site makes no mention of trickle charging. The PC+ 30W doesn’t. The Amazon.com entry may be in error. I’ve asked and wait for an answer… Will eventually update.
I bought the Powercore+ 26800 45W. It does support trickle charging.
Not sure about the 30W one though.
Trickle-Charging Mode
Trickle charging is designed to provide optimized charging to low-power devices such as earphones, Bluetooth speakers, and other accessories. To activate, press the power button twice or press and hold for 2 seconds until the LED indicator turns green.
