Cable for Roav C2pro
Hello everyone
Have a Roav C2 Pro and the power cable is broken do not power up the camera but trying other micro Usb cables works my question is Anker sells an replacement cable of the lenght that came with the dash cam?
best regards
Francisco
Your best bet is to send support@anker.com a message and ask them if they have a cable you can purchase
@franciscogallardocas I believe the cable is a 10ft generic (non-Anker branded) micro-USB to type A cable, like the C1 model
As mentioned by @Tank you can send an email to support@anker.com who might be able to send a replacement cable, whether it be the cable that is shipped with the unit or their own 10ft variation…
