Bluetooth Speakers for Capsule Max?
Quick question: I know the the Capsule Max can function as a BT speaker. But can I use Bluetooth speakers while the Capsule Max is in projector mode?
Thank you.
Yes, you should be able to pair the max with another BT speaker with more audio output power such as the Trance etc
Yes, you can pair any Bluetooth speaker with Nebula Projectors (which support Bluetooth pairing) , while you are projecting.
I personally have Nebula Capsule and pair it with Soundcore Rave Mini, Soundcore Flare 2 (with PartyCast - pair of Flare 2), Flare Mini (in Stereo Pairing),
This works just fine.
