Bluetooth speaker connection tip for Android
Ok, so there are probably a few of you out there that are/were experiencing the same issue as me. You are playing music through your nice new Bluetooth speaker and your phone rings… your speaker rings and the call is going through the speaker…It was very annoying but I found a workaround for my Android phone. Go to Bluetooth>settings> select the Bluetooth device settings cog beside the device you want to change> uncheck use phone audio and leave media audio checked . Hope this helps some of you and sorry, I don’t know the work around for IOS
It’s been a useful feature for the past few revisions of Android. No such feature for iOS that I am aware of, even under Jailbroken ones…could be wrong though…
