Hi I am having this same issue with my soundcore. Flashing blue light that doesn’t pair. It also doesn’t make the full sound that it usually does when it’s ready to play. My iPhone sees it in the settings but won’t pair with it. I have tried the following:
Forget the speaker on your device’s Bluetooth menu
Press & hold the BT pairing button on your speaker for 5 seconds
Try to pair from your devices Bluetooth menu again
I have also tried a force reset of all pairing records on the speaker by pressing & holding the BT pairing button for 2 sec while the speaker is in standby mode.
I have held the power button down for at least 20 seconds to reset as well.
Then try the pairing steps above again and nothing works.
Is my speaker just done?
VERY FRUSTRATED. PLEASE HELP!!
