I just got the ecam e and I was wondering I moved it from room to room today to do some testing with it and now the white light on the front is blinking what does this mean?
Blinking white light?
Have you looked in your manual
Good luck
Sounds like you pressed the sync button by mistake and have put it back into pairing mode…are you still getting any footage, live or recorded since the light began flashing?
I would suggest re-adding the camera again via the app…
