Hi! I’ve been using my soundbuds slim since 4 months. Last night they turned off due to low battery. “No problem”, I thinked, i charged my soundbuds but when plugged to my Pc red light and blue light bliks everytime. Then I waited 1 hour and I checked again. There is no light when I try to turn on speakers. Please help me! Thank you Everyone!!
Blinking red and blue light
Hi @Cesare_Colella have you tried to charge them using another cable and power source (USB wall charger)?
Should a different cable and/or power source fail to resolve I would suggest you reach out to support@anker.com with your issue and troubleshooting steps taken for further assistance under your 18 month warranty.
-Try a different wall charger and cable to charge the earbuds at least 24 hours no matter the indicator is on or off
- Make sure the wall charger and cable used can work properly before testing it
If the issue still persists, don’t worry, please don’t hesitate to contact us at support@anker.com by detailing your order number and the problem you come across. We will reply you within 24 hours.
Hi, thanks for the reply! I did it. When I plug the headphones in the pc or any other energy source the device gives me steady blue light (they’re charged) but when I try to turn them on there’s no light. Thanks again!
