Big Or Small Portable Chargers
Hey guys!
I am curious to hear what others think. Do you prefer a big charger, such as the Powercore 20100 or a small charger such as the Astro E1? I personally have both, and use them in different instances. I wanted to hear your thoughts.
I have one big and one small, use depends on the circumstances but the larger 26800 is normally reserved for home or holidays, my PowerCore10000 is in the backpack.
I prefer smaller ones rather than the massive ones, much easier to transport around and less weight.
both, so you can choose which carry according to my comfort, at times can carry the biggest, but in others you can only be more comfortable with the smallest
I usually use larger ones because of the many ports and capacity but if I am on the move, smaller ones suit me better so it depends on the situation
For travel I choose the big because I can do simultaneous charges, but at home I only use the small
