Hi,
I’m trying to use a 10000mAh powercore redox to power a small data logging device. However, the power pack seems to stop supplying power after a few minutes. The load is around 40mA.
Is it possible to keep the power pack supplying power with a voltage to one of the pins on the USB connection? Or is the demand too low making the power pack think it’s fine it’s job?
Thanks
Slightly baffled…
I
