Aux For iPhone X/Xs By Anker
Hello Everyone,I Am Tengo Anker enthusiast,I am Big Fan Of Anker Brand.
I Always Try To Use Anker Products,As iPhone User I Was looking For Extra Lighting Cable And Found Anker Powerline+ Just Love it,Also Using 10.000 mah Anker Power bank,So Small Portable And Powerful Its My Little friend :smiley:
I Have Idea For Anker,Since I Brought iPhone X,I Cant Use Old Aux Cable In My Car Because iPhone X have Not 3.5 MM Jack :expressionless:
I Think Next iPhone Generations Like iPhone 11-12 And Others Will Not have 3.5MM Jack Also.
So I Searched So Far,I See So Much Brands Made Aux For iPhone X/XS But Not Anker. :cry:
Maybe It Is Good Idea To Anker Make New Aux Cables For Iphone X/Xs What Do You Think guys?
Thanks!
Are you referring to a lightning port to AUX port cable?
Lighting to 3.5MM Port.Without Any Converter I Mean exectly like this
Oh to plug the latest models of iPhone into a non-bluetooth speaker?
To Insert Aux In My iphone,Its take Less time Than Connecting To Car With Bluetooth every gettin inside of car.
I would recommend using a converter. I don’t think anker makes one, but you can always get the Apple brand one :wink:
Yes,I Am Using Converter Which Included With Iphone,I Was Thinking It Was Good Idea…
Hmm, so you mean more like this? It allows you to plug an AUX cable into your iphone through the lightning port.
Yes I know I have This One,But itS better Using Aux Without Converters Just Plug And Play :joy:
So to plug the aux male connector into the female connector in the car and the lightning port into the iphone?
I Want Cable Like This,Lighting To 3.5MM jack to Plug It To my car.
But I Now I have To Plug 3.5mm Jack in car,next plug that 3.5mm jack in iphone converter Male Side,and next plug iphone converter lightning Side to my iphone,Sorry For My bad English :smile:
Yes i Know,But It Will Be Better if Anker Have That product Also,Who Knows Anker Quality Will Not Spend Bucks On Other brands.Thats All What I Wanted Say With This Topic.
Sorry Guys I reached Max posts For Today :frowning:
“You’ve reached the maximum number of replies a new user can create on their first day. Please wait 22 hours before trying again.” its Shows me This
I understand fully what you mean now, there were some translation errors. Your suggestion makes sense and could be a possible anker product for the right market! Meanwhile, there are other companies who make the exact product you want.
Unlike Anker, they are on the pricier side for MFi certified products but Belkin make this.
There’s no such thing as max posts.?.?. You should be able to post as many times as you want.,
Lightning to male aux cables do exist, search Lightning to aux on amazon and you should see some. I’m not sure what the rules are on linking to non Anker products, but until they make one that may be the better option :slightly_smiling_face:.
How many people have this cable demand?:nerd:
I’m not in need of it, but I would use it if I I had it
Same here, kind of product I would use if I had, not crazy about buying it
Yes I Know other brands have that type of aux,I think it will be better if anker will have its own.because for me and others too anker is associated to quality.
Me Me Me :joy:
