Attempting to Upgrade Homebase MicroSD Card
So, I’ve been setting up my eufy system, but to me, 16GB is a joke for security. So, I’m trying to upgrade the card. However, I cannot find information on how to get the Homebase to use it. Does anyone know where there are instructions for swapping the card?
Once you swap out the card the app will prompt you to do a format.
