Hi,
I purchased an Anker 7 ports hub - https://www.anker.com/products/A7515211
I have 2 questions - why does not all the LED light up when peripherals is connected? The Periperals are still working but the LED display for e.g. 3 or 5 does not light….
Is the hub not suitable for Apple SuperDrive? Mac OS Sierra on my iMac tells me that the Drive should be plugged in to a port with power supply. The power supply is of course plugged with power. The SuperDrive works fine on my MacBook Pro.
Med venlig hilsen / Best’s from
Karsten Jensen
