Anker Wireless Chargers Bundle Deal for $20.99
Anker Wireless Chargers Bundle, PowerWave Pad & Stand Upgraded
Anker Wireless Chargers Bundle Deal for $20.99 with discount code DMA32524
Buy here
  • harging for home and office place and charge with the pad at home or get more options at your work desk with horizontal and vertical charging MODES
  • Wide Compatibility Support for all Qi-enabled devices including iPhone X XS XR XS Max 8 8 Plus as well as Samsung Galaxy S10 S9 S8 Note 10 Note 9 Note 8
  • The Need for Speed with a high-efficiency chipset providing 10W high-speed charging for Samsung Galaxy and a 7 5W charging mode to charge iPhones 10% faster than other brands PowerWave is bridging the gap between wireless and wired charging speeds
  • Case friendly Don’t fumble with your phone case Power Wave charges directly through protective cases Rubber/plastic/TPU cases less than 5 mm thick only Magnetic and metal attachments or cards will prevent charging
  • What you get PowerWave pad PowerWave stand 1× Micro USB cable (4 ft ) 1× micro USB cable (3 ft ) welcome Guide worry-free 18-month and friendly customer service
Note: AC adapter not included
1 2 3 4
Quick Charge Recommended
To take advantage of fast charge mode, using a Quick Charge 2.0 or 3.0 wall charger is required. Standard charge mode also requires at least 5V/2A - iPhone stock chargers (only 5V/1A) can not supply enough power for PowerWave.
Note: Please use the included cable for best results.
Align Charging Coils
For best results, place your phone on the center of the wireless charging pad to ensure stable charging.
Switch it Up
Place horizontally to enjoy videos while charging, or go vertical for video conferencing or to use facial recognition technology.
Informative & Sleep Friendly Indicator
  • Flashing blue - Metal obstruction detected
  • Flashing green - Incompatible AC adapter or cable connected
  • Solid blue for 3 seconds, then off - Connected to power
  • Solid blue - Actively charging a device|
Can’t wait for a PowerLine II bundle
Good deal considering you get 2
Nice deal!
