With your wall chargers, the ones that are NOT a brick, how long is the cable that connects the ports to the outlet? I really need to know this before buying one. Thanks!
Anker USB Wall Chargers
65” from where it disappear into either end.
The socket is generic non-polarized iec320-c7 you can replace with other length if you want
Thanks! By chance, do you know what the diameter is?
It’s an 8 shape so not round, so I’d say 1/4 inch by 1/8th inch.
If you don’t like the cord replace it!
Thanks man. I really appreciate it. I was just asking because Anker does not provide any information about it, which is very unfortunate.
The use of a generic cord suits me, i replace it with short or long and UK or USA cord to suit the trip.
