Very simple and quick question.
I was using something (Raspberry PI3B+) to install a LCD display (2.4) and been having some issues getting it to install as been getting a low voltage warning using a Anker Power Bank 26,800 (not Power Core +)
Tried a few cables and then the one that came with the power bank and the low voltage warning has gone.
It came with a red cable. The screen needs 3.3a for it to power.
The LCD display seems to install correctly but I am always getting a white screen when finishing the installing. I presume it’s because the cable hasn’t got quite enough power it needs to power it up.
The question is, would this cable
have 5 V on each end?
