Anker USB C to Lightning Cable Review
Hello fellow Anker fans;
Below is the link to my review on Amazon.
Summary:
Price: about the same as Apple
Build quality: Thicker than Apple. Much higher quality.
Durability: Can easily outlast the Apple cable
Us a PD charger to get the maximum power throughput.
https://smile.amazon.com/gp/customer-reviews/R1CE17SPDZXHRM?ref=pf_ov_at_pdctrvw_srp
Nice review, it always helps to add it on amazon for other customers to see
Nice review on Amazon Smile! Wish these cables came in 6 ft versus 3 ft. There are a couple of cables that i would have already purchased if they were 6 ft… must be a reason for only 3 ft
Perhaps they are waiting to see how good the cable sells before releasing a longer version
I’m guessing they’ll probably release a longer cable soon. Cheaper to make a 3’ for testing and then if all is well, go for the longer ones.
