I have an Anker USB C Hub, PowerExpand 8 in 1. If I have the device plugged into the laptop, the laptop will not enter sleep. I have tested both with power going through the hub as well as going directly into the hub. Either way, when I shut the lid, or directly tell Windows to Sleep, fans keep spinning, the laptop does not power down. I have gone into device manager and checked the USB Root Hub that it is set to “Allow the computer to turn off this device to save power.” It is set.
Further, if I leave the laptop shut with the hub in for some time (exact time not yet determined) and open the lid again, the screen will not go back on. The laptop is not in Sleep as regular power draw has kept the fans on. Further, I can only get functionality back after hard resetting the device.
I would expect to be able to enter sleep with the USB hub. What setting or configuration am I missing?
Thank you.
