I found the solution using the current Anker driver as its another default Windows 10 security issue due to the hidden administrator account
Here are a few simple steps to bypass or circumvent the “protection error” in Windows 10, after enabling the hidden Administrator account:
Step 1: Launch Start Menu, search and select Command Prompt. Then right-click on it and choose Run as Administrator from the context menu.
Step 2: Type the following command without quotes at the Command Prompt and then hit Enter:
net user administrator /active:yes
You should see the message saying “command completed successfully”.
Step 3: Launch Start Menu once again and right-click on user-account title at the top-left of the screen. Then click Sign-out.
Step 4: At the login screen, log into the Administrator account and you will return to the Desktop of that user profile.
Step 5: Locate and run the .exe file for the program which you want to install.
Step 6: As you have already logged into the Administrator account, the Smartscreen protection will be disabled and the installation should complete successfully.
Step 7: After you have completed the installation, just log back into your regular account after logging out of the Admin account.
Step 8: Finally, disable the Administrator account that was used earlier to prevent malicious access to your system files from external sources like hackers and cyber-criminals.
Just execute the following command (without quotes) to accomplish this feat from Command Prompt: “net user administrator /active:no”.
