Hello I just bough a Anker SoundSync for my car.
Just to be clear I have a USB charger on my lighter plug that turns on when I turn on my car.
I connect the Sound Sync to that USB charger. (The USB charger works)
I needed a device that powered on and connected to my phone on turn on my car. This without pressing any buttons.
An I fount your Soundsync that was suppose to exactly that.
Before I purchased it I read the manual to check if it powered on when the USB powered.
In the manual it states: “SoundSync will automatically power on when the car is started”.
And also “When turned on, SoundSync will automatically connect to the last connected device if available. If not, SoundSync will enter pairing mode.”
So I would expect this to work.
But It does not. Every time I turn on my car it does not connect to my phone and I have to press the button on the Soundsync in order for it t power on and connect to my cellphone
Am I doing something wrong? It this a configuration that I do now know of?
Thank you for your help.
