Blue light flashing - wont do anything else. Not ANYTHING!! I’ve read all the forums, tried all the solutions, nothing works. Apparently once you’re in a bluetooth pairing loop, you’re stuck for good.
Hoping that the battery dying and restartting will help. But the battery is full and not playing anything through the headphones, that could take months!!
Does anyone have a realistic solution to this??? Cause I dont want to hear any of that “have you tried cleaning the connections” bullsh*t.
PLEASE HELP!!!
Anker Soundercore Life 2 NC - DEAD IN THE WATER
Have you tried unpairing or “forget” the device from your bluetooth menu? Then pairing it again? Can you turn it off? If not, trying plugging it in then turning it off. Maybe that will at least get you out of that loop? If all else fails, send Soundcore an email at service@soundcore.com . Hope you get it resolved.
I think I would try @Nhi suggestion. If you are in pairing loop, you can see if you can re pair the device so that it will pick it up. I am not sure about the blue light, I was thinking the pairing on it was a white light based upon my pair as well as the online instructions https://d2211byn0pk9fi.cloudfront.net/spree/accessories/attachments/77570/A3201_Life_NC_Manual.pdf?1553191052
Too late, I threw them away.
These are all things that i tried at the onset. These are all the things that most anyone would try… I literally tried everything. Shame there is no “force close”/“force shut off”… After 3 days of the same 'ole crap, I couldn’t stand it any more. They gone.
