In which ampere amount that the Soundcore 2 portable speaker should be charged? By using an adapter with 1A or 2A rate?
Anker Soundcore2 charging ampere amount
Either adapter rate will work to charge the speaker. Please note that with the 1 amp charger it may take a little longer to fully charge
Pretty sure the soundcore 2 charges at 2amps so the 2amp charger will give the the fastest change but like @elmo41683 said either will work and not damage your speaker.
