Anker Soundcore Spirit X2 Charging Case
Hi Everyone,
I have been charging my case for 2 hours and the lights keeps blinking
Most devices will stop blinking when it is fully charged.
I read that it takes only 2 hours to fully charged the case. so I wonder if there is any indication if the case is fully charged.
Thank you
If you see 3 dots and the 3rd on blinking then it is anywhere from 70 to 100 percent.
I think charge time may be affected by cable and plug in as well. So that time may vary.
Thank you Duane. But all 3 dots are blinking. I assume it is 100% charged?
Try another cable, another charger and make sure all pins are perfectly clean.
Steady means charged, not blinking.:smiley:
Thank you Chiquinho :slight_smile:
