Why does the volume slider for the Soundcore app not increase the volume gradually? what I mean is, when I use the slider in the app to adjust the volume the slider goes up and down volume in sections instead of a smooth gradual increase or decrease of volume. At night when I’m using the speaker, from volume 2-3 (assuming 0 is mute and 10 is max) goes up quite considerably, there’s no way to increase volume like a analog dial? Is this a hardware or software limitation?
Anker Soundcore Motion+ app, volume slider question
Hi @OpTicaL823 I believe this is mainly due to the coding of the app (where it increases in small incremental chunks or around 7-10%). If you have the speaker paired to a laptop you can use the volume slider at a more smooth increase.
I never used that app.
But If I use the volume controller on my laptop it works smooth without such any such “hops”.
