Anker Soundcore Life P2 Bluetooth issues
Dear Ladies and Gentleman,
i have an issue with my Anker Soundcore Life P2 Bluetooth Headphones:
Whenever i want to connect to one of my 3 devices (iphone, macbook, windows laptop) i have to completely reset the Headphones by putting
them into the case and pressing both buttons for 3 seconds. Then I am able to connect to one of the 3 (known) devices.
If i do not reset the headphones i am unable to change the connection to another device (from iphone to macbook in example), even though there is NO current bluetooth connection (because iphone is turned off).
Since this is no expected behavior for sure please advise.
Thank you.
Best regards,
Sebastian Ruf
Yes this bud doesn’t have an entering pairing mode like many of the wired buds. Yes that is annoying.
You have to ensure the last connected device is not able to be connected to before connecting to another device. I have to disable the BT of last connected device and then connect to the next device.
If you’ve paired 3 devices then you need to have BT disabled on all but the device you want.
(Moderator there is a duplicate thread one should be deleted)
