Anker Soundcore Life Note earbuds
Hi…I just bought Anker Soundcore Life Note earbuds. I opened the box and the charging place. I only found the right one was working but the left one was not. Although so, when I put both of them to the charging place, they are always charging. And only the right one gives a sign full of charges. The left one keeps on charging in ages! lol. Is there anyone who can help me with this issue? I already tried to reset both of them and still the same.
  1. Make sure the charging case has enough power. Note: after the earbuds are fully charged, the steady white light on the earbuds will shut off.
  2. Take the earbuds out of the case and see if a flashing white light comes on. If it doesn’t, try manually pressing the button of the earbuds to power them on.
  3. Try to use a terrycloth/cotton swab with a bit of alcohol to clean the contact pins both in the charging case and on earbuds to ensure a better connection.
I just got some soundcore life note wireless earbuds about a month ago and the case has stopped gaining charge. Do you have a solution?
