- Firstly try to forget the pairing records(both Liberty Air 2 and Liberty Air 2 L) on your device and turn off the Bluetooth.
- Reset the earbuds per the steps below. After the reset, you will see the white light flashes quickly on the right earbud and the light flashes slowly on the left side, which means they pair together.
–Place the earbuds back into the charging case and keep the case open.
–Tap and hold the button at the back of the case for 10 seconds until both earbuds’ LED lights flash red 3 times.
- Turn on the Bluetooth again and search for Liberty Air 2 and pair.
When there is a pop-up window for you to confirm pairing. Select “pair”. If you select “cancel” accidentally, you need to delete the earbuds from the device’s Bluetooth history and re-pair the earbuds.
