Anker Soundcore Flare Sound Problem
When my speaker is charging or on, there is always a very quiet “beee…p” sound coming from the base of it. Normally this is not a problem, but it becomes really irritating at night or when the environment is silent. Does anyone have the same issue? I have reported the problem and got a replacement, but it was exactly the same as the first one. How do you fix/mitigate the droning sound?
Hi @jaronkam , does this behaviour occur both on BT & Aux or just one? Also have you tried a new charging cable and wall plug, in case that is causing power issues or interference?
I believe it occurs whenever the speaker is on. When I put the speaker’s base close to my ear, I can clearly hear the sound.
Shoot support a message
