I’ve got an Anker SoundCore Boost bluetooth speaker (A3145). The charging port has become loose. Now I’m not able to get the charging cable to connect to the port to charge the speaker. I can plug it in, but I get now charging connection. Any ideas on how to fix?
Anker SoundCore Boost A3145 - Loose Charging Port
May be you can pull it back at the right position by using tweezers and glue it with superglue.
But you say you can plug in the cable into the socket and it doesn’t charge.
There could be a connection problem, a loose inside cable.
Difficult to say.
