I am looking to use it as a Bluetooth speaker with my PC and occasionally my phone. Can the speaker be plugged into my PC and be charging at all times when the PC is on (i.e. not removing the charge cable when the battery is full)?
Anker SoundCore 2 - can it be charged constantly?
One of the members here wrote about Nebula Capsule 2 being charged at all times. Pretty sure it is the same thing with Soundcore 2.
Yea I’d leave plug in at all times
No problem, there will be no damage of the battery.
I am swapping my speakers always, so I don’t keep these connected to the charger.
Personally I don’t leave any battery based device on charge 100% of the time; to help maintain the health of the battery.
That’s right there will be no direct damage, but it will shorten the battery life.
eg. I never leave my 11S on the charging base.
But I handle the Robot without any “programmed schedule”.
There is no need, because I let “old Willy” only work if there is a need.
At the moment often (dust caused by bath room’s restoring
